Kawasaki Side by Sides Talk about the rugged Kawasaki Sport and Utility
3010 mule
Old 04-29-2010, 03:20 PM
hatchet jack's Avatar
Default 3010 mule
have a 3010 mule 617 cc enjine,,,at low speed it wont excelerate wants to die,,,,,,,,,example shift it then start to excelerate it wants to bog down like the excelerator pump in a older car if it is bad. had it to the dealer 3 times when we get it back it is ok for about i hour then same thing
hatchet jack
Old 07-16-2010, 07:43 PM
papa hogg scoot's Avatar
What did the dealer repair? Did you check air filter, if it ran good for an hour could be an vaccum lines pinched or don,t venting proper??? Give us more information
Old 01-14-2011, 06:17 PM
jdub1048's Avatar
Folks, I've got the same type problem, at first it wouldn't idle without the choke, ran some seafoam with the gas and now it idles fine... When you put it in gear, either forward or reverse, it's like the engine drops half it's power... Have checked what I could, any troubleshooting aids would be great...
Old 03-14-2017, 11:16 PM
Leroy Begay's Avatar
Not really sure what mule I have but I'll know in the morning. Mine is similiar. It won't keep running, I noticed the air cleaner box was getting gasoline in there. I did take a rock off the linkages . It started with hardly any power like part throttle. So I started checking it out. And found the rock stuck in the throttle and choke lever. It ran good then it turned sour quick. It couldn't keep running ,I was on the side of a steep mountain trail. Got pulled out to the top.. I'm a newbie here..
merryman
01-19-2016 04:29 AM
ManuelCarrillo3
Where to Ride
07-27-2015 07:53 PM
Aitch
07-21-2015 09:40 PM
Spaceout02
03-31-2006 09:00 PM
Quick Reply: 3010 mule
