slow mojave
Old 11-18-2003, 07:24 PM
hilbilly's Avatar
Default slow mojave
i have a mojave its a 01 it does graet with power but it has no speed it will do like 45 mph. That and it has no top end what could i do?
Old 11-19-2003, 01:10 PM
kwackermann's Avatar
Default slow mojave
Hey there hillbilly- I have a 'jave too; they're excellent because of the BIG 36mm carburetor and 4-valve head. To get a bit more outta the beast it must be uncorked. First, ditch the stock airbox and that horrible snorkle, a UNI or K&N pod filter will suffice here, rejetting will be required which isnt that big of a deal. The pipe isn't that restrictive really, but personally I have a supertrapp unit with discs. This will really wake it up. Also, depending on the terrain you ride- changing to a 13 tooth countershaft sprocket will raise yer top end too, Hope this helps. If ya need more info, let me know.
[img]i/expressions/face-icon-small-smile.gif[/img]
Old 11-19-2003, 03:39 PM
gnd111's Avatar
Default slow mojave
Does it have a 12t stock?
Old 11-19-2003, 06:41 PM
hilbilly's Avatar
Default slow mojave
hey thanks for info i'll have to try it. But i just ran into another problem today. I was going down a trail and slid on some leves into a tree and bent my DG bumper i bent the one side in and i dont know how to bend it back. If you got any ides please tell . no it has 13 tooth front sprocket . it also has 20x11x10 back wheel
Old 11-19-2003, 07:35 PM
mahnster's Avatar
Default slow mojave
The stock sprocket is 12t, stock tires are 22-10-10, and the stock carb is a 34mm.
Old 11-19-2003, 08:01 PM
hilbilly's Avatar
Default slow mojave
what could i do for more top end? thanks
Old 11-19-2003, 09:37 PM
Default slow mojave
Yes- thats correct, stock countershaft is 12T. Sorry- I don't know about straightening and ATV bumper. It's a pretty stout peice to begin with, you may need to buy a new one, coulda been worse, y'know, glad it was only the bumper. as for more top end- short of juggling sprockets, I can only think of a camshaft, something I'm considering myself. But ya gotta admit, that for a 250 4- stroke, the Mojave is pretty darned impressive.[img]i/expressions/face-icon-small-happy.gif[/img]
Old 11-19-2003, 09:38 PM
Default slow mojave
Oh yeah-- anyone know the stock camshaft specifications off hand? Thanks..
Old 11-20-2003, 12:40 AM
Chris142's Avatar
Default slow mojave
Them short tires are what is slowing you down. They will improve your acceleration though.
As for "cam specs". I have seen them on t6he web somewhere.....Don't remember where though.
The valve adjustment is .008-.010 on a cold engine if thats what you ment.
Old 11-20-2003, 08:21 AM
Default slow mojave
The cam specs I'm looking for are lift, dureation- etc. That sort of info.. Thanks
Quick Reply: slow mojave
