Prairie 360 4x4
Old 01-29-2008, 02:26 PM
clintr79's Avatar
Default Prairie 360 4x4
I just bought a 2004 prairie 360 4x4 and is it normal for the 4 wheel drive to take a little time to engage.It goes into 2wd rather quickly thanks
Old 01-29-2008, 03:49 PM
harry1's Avatar
Hi, I have the '07 P360. It won't engage into 4 wd until the speed is over something like 3 mph if I recall. Yes it does often take about 1 - 2 seconds to engage and forever if you keep it below 3 mph.
Old 01-29-2008, 04:04 PM
TLC's Avatar
TLC
TLC is offline
<div class="FTQUOTE"><begin quote>Originally posted by: harry1
Hi, I have the '07 P360. It won't engage into 4 wd until the speed is over something like 3 mph if I recall. Yes it does often take about 1 - 2 seconds to engage and forever if you keep it below 3 mph.</end quote></div>
That would not be good for rock crawling,where you use 4wd at 1-2mph.
Old 01-29-2008, 04:54 PM
harry1's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: TLC
That would not be good for rock crawling,where you use 4wd at 1-2mph.</end quote></div>
Engage.... not run....it won't engage 4wd until all four wheels are rolling at this low speed, of couse once engaged, it stays engaged in 4wd at all speeds until you flick the switch back to 2wd.
Old 01-30-2008, 12:53 AM
clintr79's Avatar
Ok thanks i just wanted to know if anything was wrong but i guess not
ReconBayou
10-16-2019 02:24 AM
hueby
11-06-2015 11:34 AM
PrairieDog126
09-12-2015 05:23 PM
coolguy420
07-10-2015 01:17 AM
coolguy420
07-09-2015 09:54 PM
Quick Reply: Prairie 360 4x4
