wiring diagram bayou 300 1987
Old 05-26-2009, 07:51 PM
marteinn's Avatar
Default kawazaki bayou 300 87.2wd charging/ignition wiring diragram
if anyone have the wiring diagram for my atv kawazaki bayou 300. it is 87 and 2wd please if you can send me in email rjomi@simnet.is
any other information on this bike are more than welcome
my best regards
  #32
Old 05-28-2009, 07:36 PM
vw_lover's Avatar
Default wiring diagram for 1986 kawasaki bayou 300
I am also in need of the wiring diagram for 1986 bayou 300. If someone could please send me the diagram, that would be great. My email is vw_lover@yahoo.com. Thanks!
  #33
Old 06-02-2009, 06:38 AM
festus191's Avatar
hi could I possibly get the schmatic for a bayou 220 2x4 all that you have on this model it will start and run as long as you push the starter switch as soon as let off starter switch it dies I feel like it is a wiring problem but any help would be nice
  #34
Old 06-02-2009, 06:39 AM
festus191's Avatar
Default email
my email is festus191@yahoo.com
  #35
Old 01-22-2011, 10:31 AM
jason2188's Avatar
hey is there anyway i can get the wireing diagrams you have just bought a 300 kawasaki and it has no wires so i need to re wire the whole bike email me at jasonandholly@hotmail.com thanks
  #36
Old 05-05-2017, 01:30 PM
benniebarber's Avatar
Default bayou 300 ignition coil wires
hey guys i need to no what color wires under the handle bars on my bayou 300 do i hook to the ignition coil
  #37
Old 05-05-2017, 04:34 PM
This diagram is kinda small,but maybe you can make it out when you zoom in. Plus here's the original link.https://atvconnection.com/forums/kaw...ml#post2780755
  #38
Old 06-07-2017, 09:02 PM
Yooperjosh906's Avatar
i could use the diagrams as well. first time kaw owner and in a world of confusion with this 86 2wd 300,. jjensen9061@gmail.com. thanks a ton!
  #39
Old 02-21-2018, 07:35 AM
donnieray's Avatar
Default 2000 Kawasaki Lokota 300 what side does black yellow wire ground to from relay neg or
what side does black and yellow wire ground to on battery positive or negative from relay
  #40
Old 02-21-2018, 07:38 AM
donnieray's Avatar
Originally Posted by eddie440
<div class="FTQUOTE"><begin quote>Originally posted by: eddie440
there is a small black with yellow stripe wire that comes out rite next to the breather on the 300 that grounds to the battery that makes it fire and will make the solinoid work when you ground it. i just had the same problem on the one i just picked up . i grounded it to the battery and it fired rite up eddie440</end quote></div>
what side of battery it ground to neg or pos
Quick Reply: wiring diagram bayou 300 1987
