750 brute force clutch upgrade - ATVConnection.com ATV Enthusiast Community
Thread Tools Search this Thread
Old 10-19-2008, 05:43 PM
Default 750 brute force clutch upgrade
I dont know which clutch upgrade to get. I have a 2006 750 bf with 27 inch tires and I want the best performance for all around riding, mud, trail riding, drag racing....etc. Any help would be greatly appreciated. The bike is stock so far but I am working on getting cam mods, cdi box, rejetting, and pipe.
By the way what aftermarket part makes the most difference in the whole rpm range on these things. Thanks again
Old 10-19-2008, 10:59 PM
I wouldn't worry about the clutch until you do some of the mods to see how it acts when you pore the juice to it
Old 10-20-2008, 07:29 AM
I had great results with EPI Maroon Primary and Black Sec. springs. Take out the thinner shim too.
Old 10-24-2008, 10:10 PM
I normally do all mods myself but there is little info for the brute force so I took it to the only guy i trust around my area. He worked on my carbs and took a look at my belt, and at 411 miles with 27 inch tires he says that nothing needs attention. He says he will put a clutch upgrade on if I want, but the way the belt and clutch looks there is no point. So is there any reason if the bike is stock right now?
Also is there any websites I can look at for more info?
Thanks for the info!!
Old 10-24-2008, 11:43 PM
Forget the clutch kits. Interstate Motorsports 570-773-1721 ask for Vforce John. Clutch mahining
Old 10-27-2008, 12:59 AM
Now that I think of it, I think the EPI black secondary is about the same as the BF750 stock secondary. Springs are cheap and a clutch puller isn't that much either. i did the work myself so I did not have much money invested in it. It was well worth it performance wise.
Thread Thread Starter Forum Replies Last Post
Buying used 2007 Brute Force 750 4x4i ylomnstr Kawasaki 3 09-22-2015 12:19 AM
Exhaust upgrade and rejetting Bonzhonda300ex General Chat 12 09-17-2015 10:44 AM
Grizzly 700 vs brute force 750 Pgbama11 Yamaha 10 09-10-2015 08:20 AM
Looking for plow and winch ylomnstr Kawasaki 0 09-10-2015 06:45 AM
Advice on buying used 2007 Brute Force ylomnstr Kawasaki 0 09-04-2015 05:02 PM
Tags
2006 , 750 , belt , brute , bruteforce , carb , clutch , clutches , drive , force , kawasaki , performance , shims , upgrade , upgread
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
