Bayou 300 Carb swap(now idle surging)
Bayou 300 Carb Swap ( now idle surging )
It would great if you could give us more info on the 2 carbs this would give us more to work on .
williebee........
bayou 300 swap
i just completed my swap yesterday 1996 bayou 300 4x4 . used a 1986 trx 300 carb. carb came with the honda throtle and choke. used the honda throtle and cable the choke cable didn't fit at the lever end so iswaped out the carb end with the kawasaki end into the carb. worked perfect fuel air mix screw out about 1.5 turns idle set while quad was warmed up then set a 1/2 turn higher for colder weather starts. quad has never run so good, no gas leaks any more and more even power. air box was a tight fit but it works. needed a bigger hose clamp is all. do this swap!!!!
