2006 Kawasaki Brute Force 650i idle/backfire problem - ATVConnection.com ATV Enthusiast Community
LinkBack Thread Tools Search this Thread
Old 12-13-2009, 11:36 AM
Question 2006 Kawasaki Brute Force 650i idle/backfire problem
My son and I have a 2006 BF 650i. The machine has sat for a few months during football season with a busted CV boot. After installing the new boot, changing the oil and spark plugs the machine will not idle and will only run with the choke (fuel enriching system) on. The carbs backfire intermittenly and the exhaust shoots fire when this happens. I know that the CV boot and services I preformed had nothing to do with this problem, I feel like its a fuel or gummed up carb issue from the lapse in time the maching wasn't run. I have ABSOLUTELY no faith in my dealer so I'm not goin there. Does anybody have any suggestions for cleaning the carbs w/out disassembly. Unfortunately, this machine is having to run the E-10 (ethanol) blended gasoline that is mandatory in GA. Help !!!!!!
Old 12-14-2009, 11:48 AM
Go get a Techron based fuel additive and add it to the fuel tank and fill it up full. Ride the quad until the tank goes empty. Run 2 tanks if improvement is not seen on just one tank. If 2 running tanks don't do it, you have to disassemble the carbs and clean out the pilot jets.
Next time, add fuel stabilizer to the fuel tank if you would not be riding the quad for more than 2 weeks or so.
Old 12-14-2009, 07:14 PM
thanks, got the additive today and my son is riding it as we speak.
Old 12-15-2009, 11:36 AM
KMKjr's Avatar
Are the new plugs ok? Might also be a misfire?
Old 12-15-2009, 12:50 PM
seafoam is a miracle for gummed carbs. cleans em right out.
Old 12-17-2009, 01:28 AM
where can I get some "seafoam" ?
Old 12-18-2009, 06:57 AM
crazy650's Avatar
advance auto part its a white can with red letting on it also if you have a sport car good to use every year i do on my 05 wrx its highly moded cleans everything out real nice.
Old 12-18-2009, 05:16 PM
Thanks, Got the "Seafoam" and noticed that it is also and additive for the crankcase. The gas tank is about 5 gals. What do you think about using 1/2 the bottle for the crankcase oil and the other 1/2 for a full tank of super-unleaded. After we run a full tank thru the system we would change the oil and filter. Just wanted your thoughts.
And thanks to all that have responded this blog is a real help.
TWK and son
Old 01-03-2010, 09:10 PM
hdkawi's Avatar
ya i like the sea foam
Thread Thread Starter Forum Replies Last Post
2007 kawasaki bayou 250 NEED HELP Sjrpp Kawasaki 3 07-08-2015 10:00 PM
2006 KFX 400 starting and gear issues Jkfx400P Sport Quads 4 07-05-2015 11:33 PM
Kawasaki bayou 250 NEED HELP Sjrpp General Chat 0 07-05-2015 10:26 PM
2007 kawasaki bayou 250 Sjrpp General Chat 0 07-05-2015 10:23 PM
2007 kawasaki bayou NEED HELP Sjrpp Other ATV Topics 0 07-05-2015 10:04 PM
Tags
2006 , 650i , 750 , backfire , brute , carb , force , kawasaki , needed , plug , problem , problems , slipping , spark , transmission , type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
