Adjustable Pilot Screw?
Anyone know if this will work on a Keihin CVK-34 Carburetor that is on a '06 Prarie 360?
Tusk Fuel Mixture Screw | Rocky Mountain ATV/MC
I'm tired of fumbling around with a tiny screw driver in a tight place that gets hot. The weather has been so crazy here I have been having to keep adjusting the mixture. If this one wont work, anyone know one that will?
Thanks.
Thanks.
Don't mess with the mixture screw on the 360. If you have hard starting or stalling problem, it's more than likely your valve clearances are too tight on the 360 motor - very common problem on this air/oil cooled engine. Try to set at loose side of the spec. Your 360 will run better than ever.
Scooter's Shop
23
10-22-2015 07:04 PM
