Giovanni 110 wiring diagram
#21
Hey Lynn Edwards. We just received a brand new Giovanni 110cc Mini Atv. After getting the wheels on, fastening the handlebars, and connecting the battery my little guy couldn't wait to fire it up. Put the key in, turned the ignition to on, turned the kill switch to run, applied the brake, hit the start button. Absolutely nothing, no clicking, no cranking of the engine. Flicked the switch for the lights on, yes we have low and high beams as well as brake lights. Checked the voltage on the battery (post to post) and seems fine 12.6 or so. Checked all wiring connections and they all seem secured. Any ideas what may be causing the problem? I'm at the point of frustration now.
Thanks
Thanks
#22
on
Just for grins try shorting the solenoid posts with a screwdriver (scroll up a few posts for more instructions on how to do this). Set the brake and put it in neutral first so the quad stays put if it should start up. Turn on the ignition and turn off all kill switches. Does it start up? If not, do you have spark while shorting the solenoid?
Since you have brake lights the fuse is OK, the power side of the two pole ignition switch is working, and the safety interlock on the starter should be satisfied. The power from the brake light feeds one side of the starter button. The other side of the start button feeds one side of the starter solenoid actuating coil (the small wires). The other side of the solenoid actuating coil is grounded.
If you have a meter then measure the voltage on the start button wires. One should be 12 volts whenever the brake light is on. The other wire (and also one of two small wires on the solenoid) should be 12 volts when the brake light is on and the start button is pushed.
#23
#24
#26
hey there iam ahveing a simalr probly was the peson who requested the photos. my wiring harness is completly disconnected ans i was woundering if someone could get my a few pictures with the body off of the quad..mines a gio 110 cc beast so it will be the same as the other 110cc quads. a close up of the soliniod posts would be really great.
thanks, Eric
thanks, Eric
#27
#30
