kuzuma mini falcon 90 PLease hElp
Can any one help me It takes forever for it to start and some times it wont start at allI have checked all the conections I got good spark the carb is sucking great just wont start when does it will run fine but once it sets here we go again dont wont to burn the starter up so im letting it set till some gives me some advise to check other possiabilities I have tried starting fluid in the airbox but not any different
on
I don't know what the spec's are for your engine. Perhaps someone else knows.
I set my 150cc quad to 0.004" on both intake and exhaust when the engine is cold. If you find your valves are tighter than that then I'd loosen them up to 0.004 and see if it makes a difference. Slightly loose valves are noisy. Tight valves make a quad hard to start.
TegraQuad
1) Engine problems..
13
11-26-2017 01:40 PM
Ricardo Covarrubias
09-17-2015 08:28 AM
fourlix
02-17-2002 12:39 AM
