E-Ton Thunder 90 Oil Pump Bypass
This is a question for a new atv owner of a 2-cycle eton thunder 90. I have noticed that the oil pump is not doing its job, so what I am wondering is; Can you successfully run this atv by mixing the fuel and oil approximately 50:1 or 2 1/2 ounces oil to 1 gal of fuel and putting it directly into the fuel tank and just bypass the oil reservoir all together??? OR can you remove the oil pump or plug it so that it is not used???
sorry, i don't know what the mix is supposed to be. you may PM mywifesquad and LT80 and Mr. FireMouth for that information.....here's a hyperlink for the manual.........keep it....it's got wiring diagrams and what not.........
http://www.anythingatv.com/Technical...OM_AXL5090.pdf
exmotocrosser
09-13-2019 06:12 AM
jrooker6
04-23-2016 07:36 PM
BYC
09-25-2015 02:10 PM
Sw00p
09-24-2015 02:50 PM
