Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
Eaton Viper 90 weird issue
Old 01-19-2015, 02:54 PM
Joshwfl's Avatar
Default Eaton Viper 90 weird issue
I just picked up an 02 RXL90 for my son's birthday. He's finally showing interest in riding with us, and I was excited to get him out this weekend.
Here's the history- I bought it from the original owner and it has been sitting a couple years. I cleaned the carb (it was already clean and jets were clear), added fresh fluids and plug, and it started right up. I rode around the house a few times and parked it. Gotta say, I was impressed with the power it puts down!
Fast forward to today. Getting ready to load up, it started up easily, ran a few min. then quit. I cleaned the carb again with no change.
Here's where it gets weird:
Cold starts normal, runs for about 30 seconds and dies. Any attempt at restart and it won't fire.
If I unplug the electric choke, it will start up, run briefly and die. Any attempt at restart and it won't fire.
If I plug the choke back in it will start right up, run briefly and die. Any attempt at restart and it won't fire.
If I unplug the electric choke AGAIN, it will start up, run briefly and die. Any attempt at restart and it won't fire.
If I plug the choke back in AGAIN it will start right up, run briefly and die. Any attempt at restart and it won't fire.
Now, continue repeating this process with the same results. If I don't plug in/unplug the choke in this sequence it just cranks without even a pop. I would assume the heating element in the choke is shot, but shouldn't it run fine with it unplugged? I'm in FL, so it's still 70 here right now.
Old 01-20-2015, 07:53 AM
LT80's Avatar
LT80 Expert
Many problems with the elec chokes.
I'd replace the carb with a manual choke carb.
Old 01-21-2015, 08:43 AM
Joshwfl's Avatar
I removed the plastic cover from the choke last night and unscrewed the base. When I put it all back together I was able to screw the base in tighter so the plunger stayed in the down position. After buttoning it all back up it started right away and ran great. Hopefully it's not a fluke, the real test will be if it starts and runs great again today.
Old 01-21-2015, 03:32 PM
Joshwfl's Avatar
Started right up again today!
Hatrackr
1) Engine problems..
08-11-2015 09:03 PM
08-06-2015 11:49 AM
ghost civic
07-27-2015 03:15 AM
hondarider1234
07-21-2015 11:53 PM
cSchwartz
07-12-2015 07:42 PM
Quick Reply: Eaton Viper 90 weird issue
