Monsoon 90 wiring diagram
Help Please! I bought a basket case Monsoon 90 quad.I can figure out the mechanical parts,but I need a wiring diagram.The wiring is slightly butchered and I'm not sure what I am missing.If someone has a diagram that they could email to me,It would be much appreciated!I have read that Polaris is about the same thing,so would the wiring be the same?
Thanks, Rob
Thanks, Rob
on
I started to respond to this yesterday, but started asking myself if a Monsoon quad is even Chinese. I've never heard of one, but that is common with the zillions of chinese brands out there. I did a search on the internet and wasn't able to find much. Does anyone know if this really is a chinese quad?
Cheri, does your CDI module look like this?
If so, then it is a chinese quad. If not can you post pic's of the quad?
You say it doesn't start. Does the starter turn the engine? Have you tested to see if you have spark?
What is the history of this quad? Has it ever run for your nephew, or was the new wiring harness an attempt to revive a totally dead quad?
Monsoon Quad
The quad was made by Monsoon Motorsports that was bought out by Yerf-Dog some years ago. We going to check the CDI module to see if it matches. The quad ran before he took it apart and made a new wiring harness. There is no spark but there is some power at the coil or to the coil, I think, I'm going to confirm that and try to get more specific info. Thanks for your help. Cheri
Are you just wanting to get this running reguarding wire harness?
Take 2 wires (blk w/red & wht w/red) from the stator and plug them directly into CDI box (same color wires)
2- CDI wires (plug orange and black) Run orange wire to hot lead on coil and ground the black wire
3- The black wire left on the CDI goes to a ground
4- Make sure to run ground from engine to frame
If you have an aftermarket Kill Switch- Run 1 lead to ground and other wire to hot lead on coil. Be careful not to run hot lead on coil to wire on killswitch that runs to the metal exposed part of the killswitch.
I hope this will help you. Good luck.
To Toby: You said in your message about the wiring for the 90 cc Monsoon quad, that there were 2 black wires to the control mod said ground both of them.
But there is only one black wire, the other is a black with a white stripe. What should we do with that one? Thanks for your help. We are still not having any luck getting it started. Do you have an actual wiring diagram? Cheri
