Where to buy 2 cycle injector oil
Old 01-15-2008, 05:45 PM
rjdad's Avatar
Default Where to buy 2 cycle injector oil
I have a Eaton 90cc and I read that I need to use injector oil and not the regular 2 cylce oil. Where can I buy this oil? I Looked at Walmart and AutoZone which they only sell the 2 cycle oil. Thanks
Old 01-15-2008, 06:03 PM
onebigzj's Avatar
any dealership . walmart does sell it also.
Old 01-16-2008, 12:09 PM
LT80's Avatar
LT80 Expert
You need to read the label. Most of the 2 cycle oils can be pre-mixed or run injection.
Old 01-16-2008, 03:23 PM
rjdad's Avatar
I read the labels and did not see where it could be used with injector oil systems. I looked and saw some syntethics, semi-synthetics oils , but none that stated for injector oil applications. I went to Walmart and Autozone and found none that stated for use with injector oil systems. I was hoping not to have to go and buy form dealerships since their prices are always high.
Old 01-16-2008, 06:31 PM
LT80's Avatar
LT80 Expert
Personally, I think it's a given that it's for injectors unless it states not for injectors.
I've been using the auto zone/havoline/valvoline oils in stock machines for years w/o trouble. Says for snowmobiles (and their almost 99% injector uless ya got a antique),lawn mowers,outboards,etc.
If your real worried, go to:
torcousa.com
It has a pre-mix oil (my beloved GP-7), and a oil made for injectors.
Hope that helps. [img]i/expressions/face-icon-small-smile.gif[/img]
Old 01-17-2008, 02:07 AM
itch's Avatar
good oil is the life blood of a 2 stroke,
not a good place to save a buck besides buy a gallon 15 bucks at the stealership and it'll last 4 ever in the eton i think ours holds 2 qts and i rarley fill it.
i have real good luk with the semi sinthetic yamalube s2, low smoke too
Old 01-17-2008, 10:12 AM
onebigzj's Avatar
I use klotz. love the smell and good oil
buddieboy
12-09-2016 05:50 PM
alzgarvin
09-11-2015 08:53 AM
craacker
09-09-2015 04:32 AM
moneyrider
08-18-2015 07:15 AM
CRamshaw777
07-18-2015 05:46 PM
Quick Reply: Where to buy 2 cycle injector oil
