Suzuki LT Z 50 dies when throttle applied
New to me is a 2006 Suzuki 50 4-stroke.....bike cranks and idles great but bogs or dies after half throttle. I have already cleaned the carb, stripped and soaked etc...I can see through all the jets. The only part that looked like it needed help was the jet needle so it was scrubbed with a ScotchBrite. Air filter and spark arrestor were also cleaned. I tried running without them too.
Plenty of gas is getting to the carb, but I really feel like this is a fuel problem. What would cause a bike to idle well but bog and die as the throttle is mashed?
Not many 4 strokes will take a mashed throttle without dieing...Does it die if you slowly apply throttle?
Since you've already cleaned the carb (my first recommendation), next I'd check the float adjustment. If it's set improperly, the engine may be starving for fuel at higher throttle settings. The needle+seat (controlled by the float) may be able to supply enough fuel to idle, but when you crank it up a misadjusted float may not be able to supply enough fuel to keep it running.
Report back!
Report back!
Problem persists at normal running temp. It doesn't matter how fast the throttle is pressed. Gas is fresh. I'll install a new plug next. Choke on/off doesn't seem to matter. I've sprayed starter fluid into the carb at half throttle and it still flubs.
I wouldn't know how to check the timing, but it does crank easily.
Ltz 50
Hey I to have a problem with the kids suzuki. He was ridding it and ran fine we went out on the trails and it started to die and would not throutle up just like you would have the parking brake on and the engine would cut out. I did do the easy stuff like gass and spark. I do think it's in the wiring? Note I can now start this up with out the parking brake set. Can any body help.
