Just some LT50 info 'cause I was looking and didn't find it
#17
I was going to send this in a PM LT but I figured someone else may benefit to your reply. IF you're not to tired of me pestering you yet.
So I took the intake restrictor out.
Someone had been in the carb so I went through that. Found only one of the pilot jets in there. Now according to the parts diagram I've seen online, the 2 pilot jets are different lengths. The longer one goes in first and is on the bottom. The shorter one obviously goes in second/on top.
The thing is, It looks like I have only the shorter one. The one that is normally removed when doing this "un-restrict" deal. The carb breather was also capped off. Don't know why, but it may be useful info in diagnosing my issue.
The bike will idle with choke, but dies immediately if I un-choke. Try giving it throttle at all, dies instantly.
Dirty carb right? I can assure you no. It's obviously starving for fuel but that ain't the reason.
You mentioned not thinking I would need a jetting (main) change and I think you're right. But what do you think about this pilot issue? I gotta get the right pilot jet right? And go from there?
#18
bafisher1986
15
07-24-2015 10:18 PM
