Brand New Tao Tao 150D Chain popping off???
Old 03-27-2012, 10:01 PM
enforcer1979's Avatar
jaster,
yes i did try using different washers and lock nuts, but the tensioner threads were already stripped. as i said before multyple things were loose, likely causing the stripping in the first place.
lynn,
yes i am aware that the chain should not have no slack, unfortunately with this brand i am playing against the rules to make things work, what i did was put it max distance and tightened it up from there so that when i do hit a big bump it is capable of taking the hit.
Old 03-30-2012, 06:48 AM
Jaster94's Avatar
bummer they were already stripped out. i don't know of any other style tensioner that would work. hmmm...... i don't know if a regular turnbuckle would attach. even though that'd be an upgraded grade of metal and stronger threads. . i'll do some looking around and see if i can find an upgrade of some sort.
Old 04-01-2012, 05:31 PM
beyondupnorth's Avatar
Make sure your sprockets match and buy a O ring chain with the correct pitch for it. The non oring chains are junk and stretch very fast requiring constant tensioning and in a few rides will not do anything but pull the teeth off your sprocket because the pitch length is all stretched out
Also run a straight edge from the front to the back to be sure your sprockets are in a straight Also check to be sure the rear swing arm pivots are tight and the rear sprocket can't wander side to side.
Old 06-07-2012, 11:49 PM
Richard Graham Poster's Avatar
My chain started popping off and breaking when a motor mount bolt rattled loose and fell out, letting the engine tilt enough to throw the sprockets out of line. Check that your engine has now shifted or tilted... Also, my 150 Tao Tao uses #40 chain. I tried a 420 chain and it made the most horrible sounds as the sprocket teeth were not catching it.
  #15
Old 07-30-2015, 07:13 PM
quadman522's Avatar
Default 150 cc tao tao chain
The real important thing for proper chain adjust,ment is to measure from the front rim to the rear rim... and do this on both sides... they have to be about 1/4 on inch the same distance.... otherwise the axle is crooked... leave about 1/2 inch deflexction . the chain... if the chain tensioner is still on there. then make the chain tight.. less than 1/2 inch and the tension about 1/2 way in its full travel... this way the tensioner will tighten is too loose and loosen it if it is tooo tight when rifing... this is the same a s on the other atvs... I am a dealer and have learned how to do this... they stay on when done right... as far as stripping the threads on the adjustors....!!!!! loosen the locking bolts and nuts so they are loose... not loose good enough... as this puts force on the adjustor to pull the axle back.... you can use a 1 inch ratchet strap on one side to help keep the axle straight or to help set it so both sides will be the same distance...
  #16
Old 07-31-2015, 09:46 AM
Zrock's Avatar
Super Quad Patrol
What was said above and toss them stupid adjusters in the garbage. To many people rely on them to align things and keep them tight and then don't tighten the axle enough afterwards. I found it much easier and faster getting things right without them
  #17
Old 07-31-2015, 11:58 AM
quadman522's Avatar
Default adjustors
adjustors are need to pull the rear axle to the right length... otherwise how do you move the axle back to adjust the chain,..... BUT the adjustor do not lock and hold the rear axle... the mounting bolts for the rear swingarm to the rear axle carrier.. is what has to be tighten and make sure they are tight.... this is the most important thing... MAKE SURE THEY ARE VERY TIGHT...
  #18
Old 08-06-2015, 09:38 AM
Zrock's Avatar
Super Quad Patrol
you can pull the axle back by hand or a small pry bar..
  #19
Old 08-26-2015, 03:54 PM
whygostockcom's Avatar
Banned
There are chain alignment tools that can tell you if the rear end out of alignment. Less than $20.
  #20
Old 03-29-2017, 09:04 PM
Austin Belcher's Avatar
Originally Posted by JLovinOU
HELP! My boyfriend and I purchased 2 x 150D Tao Tao's last week and after putting them together the chain on one of them keeps popping off. My boyfriend re-welded the sprocket as the one from the factory was total crap and wasn't aligned properly which he thought was causing the issue with the chain, but that doesn't seem to have fixed the issue. The chain keeps making this loud popping noise and then pops right off. He's getting so frustrated and I'm wondering if it could be the chain itself? Does anyone know the model of the chain I would be looking for? Has anyone had this issue?
Help would be much appreciated
Jessica
well i have a 125cc tao tao and i replaced the hole back rear but the tao tao is for messing around but at my real dads i have a racing one bc we own are own track and the tao tao are meant to be braking down alot we rebuilt are from frame up
Hondapolaris8596
07-28-2016 03:17 PM
Randy Marsh
3) General Discussions..
21
11-10-2015 01:45 PM
Anomers
08-16-2015 11:06 AM
Hankey Pankey
07-31-2015 05:50 PM
toonces
07-23-2015 02:21 PM
Quick Reply: Brand New Tao Tao 150D Chain popping off???
