KFX80 eletric starter issue, need some ideas.
Hello,
I own a 2004 KFX80 and started the machine after sitting for two months. When I shut the engine down and attempted to start it back up, the electric starter was sticking. I had to physically disconnect the battery, even though the ignition switch was turned to the 'off' position, and the starter button 'depressed'.
I'm unsure if the issue is with the ignition switch, starter button or both.
Has anyone experienced this with their machine before? If so, any ideas and/or suggestions would be much appreciated.
Thank you,
IronBear
Thank you,
IronBear
When I reattached the battery cable, the starter started to spin. Like beyondupnorth states, the solenoid could be stuck causing the issue. I've seen this for myself on the old Fords with the solenoids mounted to the fenders. Not sure if I should replace the starter or not.
