Chinese No Spark
Old 06-10-2013, 10:32 PM
Dieselcrazy's Avatar
Default Chinese No Spark
I am new to these chinese atv's and they seem to last as long as anything else made there my issue is my daughter was ridding the atv the other day and it died oh here I just pushed it back into the garage and figured I would deal with it later the bike does crank fine but has no spark I have another one of these so I tried switching the cdi box to see if it was that simple still no spark. When I say no spark I have the plug removed but still in boot next to engine and getting no spark at all. I found the remote kill/starter box under the head light and unplugged it opened up the box and found a capicator loose on the board and a resistor burnt up cause unknown never had the remote stuff when I bought it used. what I went through and checked connectors and connections all over the bike and now I am to where I need someone who knows more about these to help I also unhooked the 4 wire black remote box that is also part of the remote kill and still had no spark
Old 06-12-2013, 09:41 PM
Jaster94's Avatar
sometimes the left hand slider kill switch is the culprit due to loose connections. did you check that one?
Old 06-13-2013, 04:37 PM
I didn't check it with my multi-meter but the way this one is if you switch the switch over to kill the bike it will not crank so I was working on the assumption since the bike would crank then the switch was working
jeepwheelin02
1) Engine problems..
07-18-2020 06:42 PM
Tomtom86
08-03-2015 02:41 PM
Waddell4436
07-20-2015 09:46 AM
Unzzy66
07-11-2015 10:01 PM
Quick Reply: Chinese No Spark
