Help with Eton Viper 90r
I purchased a Eton 90 with reverse for my daughter. I know the ignition switch is bad. I disconnected the switch at the plug. If I put a jumper wire from the red to the brown and hit the start button the motor will turn over but I have no spark at the plug. Is this because of the ignition switch or should there be spark at the plug when I do this?
