No spark issue from kill switch troubleshooting
Hello all,
I recently bought a used BMX Loncin 110cc chinese ATV that was lightly used.
It has a no start / no spark issue. I have found out that when you remove the kill switch wire/pin from the 5pin CDI harness plug it will spark and run fine. Obviously this bypasses all the safety stuff and I have to pull the plug wire off to kill the engine.
I've taken apart the kill switch and looked around and see no issues with it. How can I further troubleshoot this problem?
Disconnect the remote start/kill/alarm if equipped and also tether kill switch then check again as these can be a problem with no spark issues. If no change then you will need to start tracing the wiring to find a shorted wire in the harness most of the Chinese quads I have worked on have all splices in wire right next to each other and very little tape that is usually coming loose. Good luck
I kept digging around I wasn't even thinking about the remote box... I unplugged it and then I have spark! So, the remote box must be faulty. I opened it up and looked around and don't see anything pinched, etc though. Having trouble finding a replacement but at least I know what the problem is now.
Okay, I've unplugged the remote module but now I can't kill the motor.
The handlebar kill switch and/or ignition does not kill it. I realized the ignition would not kill it but thought the kill switch would at least work.
If I take a jumper wire from the 'kill switch' on the CDI and just ground it then it kills. So I have a black/white wire and green wire on the kill switch wiring. I thought I'd be able to run a jumper wire from the green kill switch wire to the 'kill switch' wire on the CDI but that didn't work.
How do I get the kill switch to work now???
ranvette
07-04-2015 06:13 PM
