Loncin 86cc turns, but dont start
Old 11-23-2015, 07:12 PM
fhorta's Avatar
Default Loncin 86cc turns, but dont start
quad been.sitting outside for months. checked spark plug looks good . motor turns and even starts , stays on for about 7 seconds, then dies. if If I give it gas while on, it will bog down and die. any prior experiences , ideas, sugestions are greatly appreciated.
Old 11-24-2015, 03:24 AM
Water or dirt in carburettor. Clean it out by removing the float bowl and blowing bowl and jets out with compressed air. If it is water, there will probably be more in the fuel tank.
Old 11-25-2015, 08:16 AM
LT80's Avatar
LT80 Expert
ditto..
Old 11-27-2015, 02:07 PM
fhorta's Avatar
took out carb, was water in bowl..cleaned it, blew it, put it back and still same..had dumped out fuel.from tank and refilled with feesh gas...what more can I check?
Old 11-27-2015, 02:09 PM
fhorta's Avatar
threw in new spark plug too just for goodmeasure, still not starting. starts momentarily but wont stay on.
Old 11-27-2015, 05:15 PM
LT80's Avatar
LT80 Expert
I'd do a compression test.
Hopefully it's above 90.
Old 11-28-2015, 02:34 AM
Clean the carb out again. Water can fir up the jets, did you make sure they were clean? Also water is almost impossible to get out of the tank completely, it often takes several carb cleans to get rid of the remaining droplets.
Old 11-29-2015, 03:45 PM
fhorta's Avatar
so I took off air filter to give it another cleaning and before reinstalling I decided to cover the air filter hole with hand and tried starting and it did start and stayed on. then it starts to bog down then I remove my hand and runs better, then bigs down, then cover hole again, and runs better and can do that for a while...if I just reinstall the filter it will.do.the same of starting for a second or two and die. what could.this mean? think im getting close to the issue..
Old 11-29-2015, 04:00 PM
fhorta's Avatar
I put a piece of cloth to.cover up where the air filter goes and quad is on and stays on. but If I give it gas it kind of wants to bog down. its ideled kind of high.and.trying to adjust the idle cable wont make a difference.
Old 11-30-2015, 02:55 AM
Either you still have a partly blocked jet, or an air leak into the manifold. Did you check that any O-rings were in place when you put the carb back on?
Quick Reply: Loncin 86cc turns, but dont start
