Eton 90 Dxl starting issue
Sorry if I'm in the wrong spot. Looking for some good answers so I can get my sons Eton 90dxl Sierra ready by Christmas.
Bought used off a guy I work with. His boy rode it and it did fine. When I purchased it didn't start. It had been sitting for a few months. I replaced stator, new plug, new battery. It started up and ran fine. I decided to take carb off to clean it all up due to it sitting a while. Got everything back on and I can't get it to run. It will turn over and idle for about 3-5 seconds and die out. I have messed with a few things but I'm at my end. I just want my boy to have a decent quad for Christmas.
Any ideas? Compression seems good. Just won't hold idle.
If you can silicone a crack on the box do it. May be hard to find some parts if it's an older machine. Plus always clean and oil the foam filter. You might look here for oem parts though if you wish to do it right and if they still have your parts. Alpha Sports OEM Parts Catalog - E-Ton Parts Diagrams
the gasket on the box is broke so I didn't know if I could just silicone around the box where the front and back meet.
Can I clean the filter with soap and water?
Okay thanks. I've had pretty good luck with parts on eBay and get2itparts. Thanks!
Again if it was running fine before you tore into the carb,you may have done the damage to the gasket/air box taking it apart.. Just try to repair the gasket/box and see how it does. If it doesn't help then retrace you're steps on the carb. You can check reeds when the carb is removed. Just take one step at a time until you find the problem.
