LT 80 Carb Rebuild Quetstion
Old 02-03-2016, 03:37 PM
mtnxtreme's Avatar
Default LT 80 Carb Rebuild Quetstion
Never leave a carb rebuild unfinished for a month, there is a very small threaded jet the book calls a secondary air jet, where does it go? Can anyone tell me, and do you really need the rubber shroud over main/pilot jet , mine is kinda shabby ?
Old 02-03-2016, 05:31 PM
LT80's Avatar
LT80 Expert
That air jet is in the front of the carb and I've never messed with it. It's really small.
I leave that rubber boot off.
Old 02-04-2016, 06:38 AM
mtnxtreme's Avatar
In my manual it shows it in the right hand hole of carb flange where boot goes on I put it in there and it just spins, doesn't thread now I cant get it out. Is that the spot your referring to LT80 ?
Old 02-04-2016, 08:32 AM
LT80's Avatar
LT80 Expert
I think so. The boot you're reffering to is the air filter boot, right?
Old 02-04-2016, 12:21 PM
mtnxtreme's Avatar
Yes the air boot side of carb, opposite engine flange. I wonder if that little jet has much effect and weird it doesnt thread in ?
Old 02-06-2016, 09:43 AM
LT80's Avatar
LT80 Expert
That lil hole will have a effect I'm sure.
I wish I could advise on the hole. I've never ever messed with it.
Them lil holes start getting plugged and I get a new ebay carb.
Old 02-07-2016, 09:13 AM
mtnxtreme's Avatar
Would you have a carb around you could take a peak and confirm if you see that jet in the right hand hole looking at the 3 holes side of carb ?
Old 02-07-2016, 09:20 AM
LT80's Avatar
LT80 Expert
I'll be in the garage later, I'll look.
Old 02-08-2016, 05:19 PM
LT80's Avatar
LT80 Expert
Ok as you are looking at the carb: small hole on left has a brass piece at end.
Middle hole is small and deep with nothing showing but hole.
Right hole: has a brass piece down in it (that air jet I presume). There is no slot to unscrew the brass with.
All the carbs I looked at are the same.
arcadefreaque
04-14-2017 10:18 PM
Landingzone
02-10-2016 01:12 PM
JOE3824
02-01-2016 02:52 PM
frankmako
01-17-2016 08:51 PM
Rick1975
Technical and How-To Articles
12-16-2015 01:34 PM
Quick Reply: LT 80 Carb Rebuild Quetstion
