Ported cylinder with Honda piston - LT80
Hi
Just bought a used ported cylinder with a piston on Ebay for my sons LT80. The piston is from a Honda CR80 year 1982. The top off the cylinder is milled 1mm down to fit the Honda piston. The cylinder has an engraving "The Works"
Has anyone ever hear off this setup ?
Best regards
Kell
Best regards
Kell
What kind of mods. will you recommend ? 4 rollers and cut the rear shoes to 180 g ?
Where can I get a bigger torque spring and from which mashine ? Does Suzuki make them for the LT 80 ?
The biggest diffenrence is the round part on the side which is cut out on the intake side of the piston. A stock Suzuki piston is straight om both sides.
See the attached picture
Best regards
Kell
Best regards
Kell
