Polaris Outlaw 90 manual
Usually this is caused by belt dust and dirt. I've had to clean plenty of them. You leave the kick starter attached,pull the cover.Use an air nozzle first to blow out the dust,brake cleaner afterwards to remove the hardened residue. Deep Creep,PB Blaster or wd40 to loosen things up. You can also use a light coat of grease. Main thing is "Don't" go too far down on the kick starter or the yoke spring can jump out of its slot. If you still want a manual you can get one here for your model for 5 bucks that shows more in detail on the kick starter.Polaris ATV Service Manuals PDF Download
