Outlaw 90 clutch rollers and air filter question
Can someone help explain the weight sizes on the clutch variator. I'm looking to replace these on my son's machine but they offer 3.0 grams up to 8 grams. What is the performance difference in the weight sizes. Also, looking to replace the air filter setup with an Uni style air filter. He races in sand, mud, you name it. Do I need to re-jet the carb if I add this style of air filter?
Are you confusing wights on the larger machines with the rollers on the youth models?Or is there an aftermarket source for these now? These have used basically the same style and part number all the way up until the 2016 models.Item#3 As far as jetting,check how it runs with the pod filter on,whether it bogs or hesitates plus the color of the spark plug. Needs to be medium tan to light brown on the electrode.If whitish in color,then jetting up may be necessary.
Lighter weight rollers,quicker clutch response.Heavier rollers,slower clutch response time,but usually more torque,pulling power. Why not go to the middle of the pack and see how it does.
They didn't use grease that I know of. Those style of clutchs are much easier to install without flopping a roller.
I think you will find some bad rollers.
Unless you've done motor mods,IMO,You should get stock weight rollers.
If you want to experiment with lighter total roller weight, leave 1 roller out and see if it reacts more like you'd like it to.
Less weight= higher stall/less top end speed. More weight=less stall more top end.
If you put lighter rollers in, he may have to rev even higher than now to get the clutch to engage.
