Blown Pistons
Old 05-02-2010, 02:06 PM
fishgamble's Avatar
Default Blown Pistons
I was thinking about buying a KTM, and I heard that if I blow a piston, the sleeve has to be heated for removal and installation of a new one. Can anybody verify this? If so, I heard that it's difficult to find someone to work on this. Is that true?
Old 06-18-2010, 04:50 PM
captjanes's Avatar
that all depends on how much damage you does.. if you can stop your engine before she beats her self up then u mite only damage the piston and not hurt the wall or liner.. i am after overhauling many engines and just doing the piston and rings beause i could still see the honing marks on the liner. the worst fault about this situation is that every machanic got a different opinion lol. but if you did have to change the liner i cant see it being a big deal you only press it out and press the new one back in. sometimes they stick on me and i use a welder to run a bead of weld down through the liner on the inside and when it draws the liner will drope right out. i done a engine one time i made 9 passes before it dropped out, she was stuck really good.. hope this helps
Old 06-19-2010, 01:15 PM
dirtdevil96's Avatar
You might do a search on maxpowerrpms website.They build the "IceCube" big bore kit that you just change out the entire jug and piston.Hope this helps...
Old 07-21-2010, 09:53 PM
xxaviera55's Avatar
A blown engine cylinder piston ring is a major engine mechanical problem that severely disrupts the normal operation of a vehicle's engine. Each engine piston has a piston ring that is responsible for sealing engine combustion gases within each engine cylinder, a job that is critical for maintaining proper engine power and function.
________________
Electronic Cigarette
E Cigarette
Old 07-24-2010, 01:51 AM
nivrenor's Avatar
I heard about this a week ago from my friend. Dunno if its true though. But I think, it will depend on the extent of the damage.
exmotocrosser
09-13-2019 06:12 AM
kodiacrunner
10-04-2015 11:52 AM
2many2ride
09-27-2015 04:35 AM
Quadzilla Heritage
09-25-2015 01:39 PM
nastyblaster100
09-13-2015 01:19 PM
Quick Reply: Blown Pistons
