Cabellas ATV Won't Start
Old 04-13-2015, 07:41 PM
dgface's Avatar
Question Cabellas ATV Won't Start
I have a Trail Tamer 260 with electric start and it does nothing when I push starter button. I have replaced the battery and lights work but won't turn over. It ran great until it set-up for six months following back surgery. Any help would be appreciated.
Old 04-13-2015, 08:06 PM
Scooter86's Avatar
Knows Old ATV Questions!
I would start by checking if there is a fuse that may have blown, or possibly a loose or corroded terminal wire or ground. Likewise there may be something going on in the starter switch itself if the only thing effected is the starter. I take it no backup starting on this model?
One quick thing you can try is take a battery, wire negative to a ground on the frame, and touch a wire from positive to the terminal on the starter motor. That will at least let you know of the starter is functional.
Old 04-13-2015, 08:08 PM
If you have room in the start button area,possibly a little electrical contact spayed through a nozzle may help. Possibly sitting up for that long could have left a little corrosion on contacts.May be that simple if it was running okay before. Plus check all connections including the battery and ground wires.
Old 04-13-2015, 08:19 PM
dgface's Avatar
It only has electric start but no pull start. No fuses are blown and has a new battery. I will try jumping the starter and look into the switch contacts. Thanks
MikeyBoyesq
11-27-2020 02:44 PM
Mkp
03-28-2020 03:50 AM
tiresharkdbb
09-03-2017 02:06 AM
garyt1975
06-05-2015 08:53 AM
1000gade
05-27-2015 12:37 PM
Quick Reply: Cabellas ATV Won't Start
