american sportworks odd start - ATVConnection.com ATV Enthusiast Community
Thread Tools Search this Thread
Old 08-27-2016, 08:04 PM
Default american sportworks odd start
I have a American sportworks trail wagon 265cc it starts and runs fine with pull start but no headlights will not start with key (dead) I have charged battery, charger says it is charged and in working order checked all the obvious have found nothing yet help thanks
Old 09-29-2016, 11:58 AM
Kymco 450i's Avatar
First off if it is still under warranty then return it to the dealer, if you start working on it then your remaining warranty may be in jeopardy. Other wise you need an electrical tester and start checking things out. Is the starter good? A quick direct connection from the battery will confirm that, hook up tester to starter leads and see if you have power there when you turn the key. If not then start tracing from the battery to the starter, going thru the key switch checking for current along the way. When you get to a point where you have no current then that is your culprit. Could be a loose or corroded connection, go thru all electrical connections and clean and reattach all of them. I have a small brass brush about the size of a toothbrush that I use, have to do that on my boat every year from being in a wet environment. Poor electrical connections can cause all kinds of issues.
Thread Thread Starter Forum Replies Last Post
Headlight wiring Rluckie Kids Quads 2 03-07-2016 07:03 PM
pull start on 2001 polaris trailblazer 250 help please !!!!!!!!! reezy Polaris 16 02-21-2016 06:31 PM
American Land Rights Association - Land Rights Network TopCat Land, Trail and Environmental Issues 0 05-19-2001 01:51 PM
check out website Rocky Performance Mods and Project Quads 0 03-01-2001 01:55 AM
Runs great and won't start!!!! HEEEELP Zorro Performance Mods and Project Quads 4 01-07-2001 05:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
