How do i bend a curve in 1/8 metal to build a plow????
I want to build a snow plow, but how do i get the curve in the metel bent???
I have heard of using a metal garbage can cut in half or a 55 gal drum but not sure how strong they would be I push logs around too so i want it strong. Suggestions?????????
I have seen people bend heavy metal like this by heating one side of it with a torch and tossing cold water on it. It makes an awful noise, but with enough heat on one side of the metal, it can be made to curve. Just like when welding, metal always curves with the heat. I think circle track car guys can set camber into a solid read end with this method also.
I made my own plow out of a rider mower blade ( http://waynesphotoes.homestead.com/plow.html ). It wouldn't be strong enough for pushing logs. You could check out an old hot water heater tank cut in half.
TheATVSuperStore.com
TheATVSuperStore
09-09-2015 07:43 PM
