help!!! i need info on motor boring
just to bore your motor you need either a low compression oem piston kit or a high compression je or ross piston kit. Then you take your cylinder, piston and rings to your local machine shop and they will bore it for you.
The cam and all that other stuff doesn't have anything to do with just boring your motor.
What kind of quad are you doing this to?
Mojave250A
07-11-2015 10:38 AM
TLC
07-11-2015 02:28 AM
