Cleaning Foam Air Filter with Soap and Water???
If it were going to using my method, it would using any other method, you will be able to see that the filter is quite clean. I have never experienced dirt in my air intake tract until using a K&N filter & one other incedent years ago with a foam filter that had deteriorated near the seam and tore off inside the air box.
I also usually coat the inside of my air intake with a little filter oil, when I remove the filter I take a white dustfree cloth (parents own a bodyshop, so they are readily available) and wipe the inside of the air intake to see if any dirt is passing and collecting in the oil.....
rottwolf-
I have been using my method as posted earlier with coleman latern fuel for two years and have had no problems with the glue or filter breaking down on my uni. If you talk to one of the major filter manufactures such as Uni they will tell you to use kerosene first to break down the oil because it is not as harsh as gas.
I just dont recommend standing around drinking a cold one and smoking with your riding buddies while doing this
GEE WIZ PEOPLE-NEVER EVER USE A HIGH FLASHPOINT SOLVENT ON A FILTER(GAS,KEROSINE,ETC)IT WILL EAT THE GLUE THAT BONDS THE FOAM TO THE SEALS AND IT DETERIATES THE FOAM AND DRIES OUT THE RUBBER.USE SOAP AND WATER OR A FOAM FILTER CLEANER-YOUR CLEANING OUT THE DIRT, NOT THE OIL SO SOAP WORKS FINE . LET IT DRY GOOD TOO
Sorry man but kerosene will not break down the glue in the filter. The owners manual on my bike says right in it to use kerosene to clean it up. Gas and coleman fuel may be a different story but kerosene is an excellent oil/grease solvent that can be used on many different things. It will however eat some plastics but that is not the issue here anyhow.
#15
I have been doing it the same way to all of my ATV filters for years and have never had any type of problems.
I use foamy "Gunk" spray in a can. It cuts the grease immediately and leaves the filter perfectly clean, dry and in new condition. I then oil it up with filter oil and re-install.
No problems ever and it is very quick, easy and zero mess!
#17
#18
i usually use diesel, because of explosion possibilty with a gas, then just get some soap and water and work the soap real good in to the filter and then dry with a hair dryer or wait for drip dry, and reoil lightly if u put too much oil on it it will choke down for awhile. i use dish soap
#20
