Snowmobile Motor On A Quad Frame????????
I used the snowmobile clutches and went to a jack shaft with a goodyear eagle pd drive belt to the atv transmission. The atv tranny gives me forward and reverse. I had to extent my frame 16" to accomidate everything. ( Mostly the pipes ) I have a few pics in my profile page.
great pics of the sport with the 600 triple in it!!!!
aaen used to make a WICKED!!!! 660 kit for those motoer they were awesome in the sleds
but I still think that the weight savings by using the electronic reverse would be enought to offset the added weight of the larger sled engine overe the stock motor and trans
I'm going to look for a sacked sport this winter
ebay has the odd small block 500 or 600 twin for sale
600 small block twin with VES and electronic reverse would be an insane setup
small package , reverse and probably 110 horse with twin pipes
DO YOU HAVE NEUTRAL on you ATV??????
the clutches neutral out at idle!!!!!
the electronic reverse when activated slows the engine idle down to a couple hundred RPM then fires the ignition on the exhaust stroke causing the engine to spin backwards
the secondary clutch is special so it will work in reverse
NOTE
the ONLY reason that SKI-DOO dumped the rotary valve intake in favor of reed valve was to make the electronic reverse work!!!
NOTE
years ago when we did ice drags with our drag sleds we rigged up a bracket with a wheel on it that stopped the outer shive on the primary clutch from moving so we could clean out our engines like you want to do
the wheels were held in place with a clutch lever off of a dirt bike
