Rear brake issue on a 97 trail boss - ATVConnection.com ATV Enthusiast Community
Thread Tools Search this Thread
Old 10-07-2016, 07:55 PM
Default Rear brake issue on a 97 trail boss
I have a 97 trail boss. The rear rotor seams to be shifting to one side binding the brakes. Is there a keeper I am missing? There is no groove for a c clip. The end of the shaft the rotor sits on is tapped.
Old 10-07-2016, 08:45 PM
Rear rotor on this old model was a floating disc.1997 Polaris TRAIL BOSS (W97AA25C) Gearcase/Brake Mounting Trail Boss | Cycle Parts Warehouse Most rear brake problems were in the caliper itself. You increase or decrease pressure on the pads by loosening the outer nut and turning the bolt out or in. The foot pedal would rise or fall as you adjusted it. Also frozen piston,or a stuck inner pin(item#13) could cause pads to have constant pressure on the rotor. 1997 Polaris TRAIL BOSS (W97AA25C) Rear Brake Trail Boss | Cycle Parts Warehouse
Thread Thread Starter Forum Replies Last Post
900 Sport or Trail Razor? RticKwad Polaris Side by Sides 13 10-22-2016 05:02 PM
2002 Rubicon broken drive shaft? Ak Rubicon Honda 2 10-05-2016 11:18 PM
700 Trail Vs. Sport RticKwad Polaris Side by Sides 1 10-04-2016 07:16 PM
New Trail Monterey TN Chrisdun Where to Ride 0 10-03-2016 06:47 AM
1976 Honda Trail 70 mywifesquad Vintage Machines.. Pre 1975, Dirt bikes, ATV's, MiniBikes, Snowmobiles, etc.... 3 09-15-2016 04:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
