Polaris piston and rings - ATVConnection.com ATV Enthusiast Community
Thread Tools Search this Thread
Old 10-26-2016, 05:00 AM
Default Polaris piston and rings
I'm just wondering if anyone would be able to help find or point me in the right direction for new piston and rings for my 1993 Polaris 300L 2 stroke. Every time i look on Ebay it comes up with 250L and 350L, which one do i do with? Can't find anything for 300L. My engine cylinder is the same as 250L but mine is 300L, do i go by 250L?
Old 10-26-2016, 08:29 AM
Can't beat a forged Wiseco as a better replacement for the oem cast piston. Available in over sizes up to 2 mm over standard bore size. Just measure the cylinder to find what over size is needed to clean up the cylinder. Going too large really doesn't accomplish anything and takes away from the cylinder sleeve.Doesn't matter if it's an Express,Explorer,etc as all the engines and pistons are the same.wiseco Polaris 300 pistons | eBay Plus the first 300 to come out was a 94 model,not a 93.
Old 10-26-2016, 11:19 AM
DirtDevil101's Avatar
Old 10-26-2016, 02:28 PM
Cheers mate, i was only going on what i got told by the seller
Old 10-26-2016, 03:06 PM
Sometimes sellers don't even know what they own or trying to sell.. Good luck with it.
Old 10-26-2016, 03:07 PM
Cheers
Old 10-26-2016, 10:20 PM
jumbofrank's Avatar
Moto Psycho
If you can find the VIN the 10th digit will tell you the year. It may make a difference on parts in the future. ATV Vin Number : Check and Decode Your VIN
Old 10-27-2016, 01:36 AM
Where would the vin be? I tried looking for it on the weekend but couldn't find it
Old 10-27-2016, 03:16 AM
Quote:
These older models predate the 17 digit frame numbers on the left a-arms. The model number W94,95,96,etc is on the right side frame down tube by the gear shift. The serial number is on the back side of this tube.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
