Setting up Keihin PJ34 carbs on a Banshee
Keihin carbs can be lots of fun to set-up initially. The different circuits of thecrbs overlap more so than mikuni roundslides. I am running 34pjs with 168 mains, 58pilots, CGL needles with clips 3rd spot from the top. And its running perfect. My setup is 370 long rod with ported cylinders, portmatched pistons and case. V-force reeds, coolhead with 17cc domes, Toomey T-5 pipes. I run yamalube 32:1. I hope this can help you out some.
07-07-2015 11:00 PM
