Polaris is messed up
Already everyone have another problem with my Polaris Went driving today with some friends and my atv started to make some noise so i stopped. Then i started driving and it wouldn't go over 15 mph so i am not sure whats is wrong with it but i am pissed and starting to get mad with polaris but please help me figure this out. I also took the clutch cover off and the clutch would not squize the belt and make it ride up so not sure Please help.
ONE LAST THING,not related to the clutches,but remembered on the Magnums that there is a COUPLER that connects the short prop shaft to the rear gear case from the transmission that can get dry and strip out basically doing the same thing,Can start out ok,but when throttle applied the splines on the coupler will slip. There is a hard to reach grease fitting (NOT on all models) that a lot of people over look. Just a thought.You might jack up rear of atv,place in drive,try to turn rear wheels and see if coupler slips? Worth a try!
Derek Allen
07-22-2015 09:25 PM
Shifts
14
07-13-2015 08:41 AM
