No SPARK on my 04 predator
Old 09-07-2011, 10:16 PM
daytonrocketry's Avatar
Default No SPARK on my 04 predator
i posted on here about a month ago that my predator was running then just stoppped dead wouldnt turn over andf there was a clicking sound for the 20amp switch/fuse? well my best guess after messing with everything. i pulled apart as far as it would stretch the emergency tether. it then would turn the engine but now the damn thing isnt putting any spark to the plug. i dont understand thats system anyway there is a wire that splits off the coil one comes in from the cdi box and the other goes out to that tether system that the other side of it goes to a ground does the coil act kinda like a magneto? or does the techer when pulled out short out the coil stopping a spark to the plug? i cut the wire coming off the coil to the tether to see if that would get me spark and it didnt. im considering hooking that wire back together but grounding it bypassing the tether. btw i have swapped cdi with a friend both work changed the coil and wire and plug. it has to be in this tether thing?
Old 09-07-2011, 10:23 PM
could it maybe be the MAGNETIC SWITCH im not 100% what it does the 2 little wires that come off of it?
Old 09-08-2011, 02:01 AM
Try by passing the tether and see if you have spark,if not,remove the black wire from the cdi and check for spark.If has spark could be in the ignition cutoff or switch or a ground problem. Also the tethers are a nuisance anyway and best left on the youth models! The wires on the magnetic switch(solenoid) powers it up from the ignition switch and transfers the voltage to the starter side of the switch(solenoid) when cranking. OPT
Old 09-11-2011, 09:21 PM
i bypassed the tether took it all the way off. still no spark but when i cut the black wire to the cdi we got spark!!!! now the only question is why? what does the black wire do and can i just runb it that way?
Old 09-11-2011, 10:57 PM
You either have a short in the left handle bar kill switch or the cdi black wire can be the problem! Trace from the black wire up into the left control switch harness and see if there is a direct short in the harness or inside the control switch itself. If all is ok,then the cdi could be the problem and the black wire(kill wire) could be shorted out inside the cdi itself when connected(but sounds like a direct short past the cdi wire grounding out). Have had this happen on other Polaris atvs OPT
Old 09-12-2011, 05:06 PM
ty old polaris tech you have been a god send i trace it and there seems to be a short behind the front plastic. i took it off found what i think is the problem and rehooked up the black wire and it fired up. ty ty ty for all your help
Old 09-12-2011, 05:15 PM
Glad you found it,was just about to pull what little hair I have left on this one! OPT
Hankey Pankey
07-31-2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
07-29-2015 10:57 PM
1966F100
07-14-2015 12:19 PM
1966F100
07-12-2015 03:08 AM
steveo612
07-11-2015 08:35 AM
Quick Reply: No SPARK on my 04 predator
