polaris sportsman 500 2004 wont start - ATVConnection.com ATV Enthusiast Community
Thread Tools Search this Thread
Old 11-30-2011, 03:54 PM
Default polaris sportsman 500 2004 wont start
Last night I was riding my quad and had no problems went to make a turn and it just died, know i can't get it to do anything it has gas and i've had a charger on it all day. I can't even pull start it. Any suggestions?
Old 11-30-2011, 05:28 PM
Welcome to the forum! First off a little more info! Do you have power to the instrument panel?? Will the engine turn over? If you don't have power and it happened as you turned,could be broken/shorted wires under the headlight pod? This is where the ignition switch ties in along with most of the other wires into the main harness.This area is subject to a lot of stress on wiring from turning and twisting and also the metal headlight support pod bracket is bad about rubbing wires and shorting out! Don't over look the obvious first, which is the battery and connections! PLUS,ecm modules were bad about going out causing problems! Also they are under a recall at NO cost to you if it hasn't been replaced,Plus some of the replacements have failed also!! Hope this gives you a start on tracking down the problem! OPT
Old 11-30-2011, 05:44 PM
no i don't have any power. i've had it charging all night i can't get lights or anything to turn on. how do i know if its the ecm's and where are they located. i checked all the wiring under the lights it all looked good but i'll double check. you think i should try a new battery. it was working fine then just died the turn was a sharp turn. i'm baffled and about to pull my hair out. any suggestions, greatly appreciated.
Old 11-30-2011, 05:58 PM
Just from what you've described,it still could be a short or bare wire somewhere? Sometimes you have to really pull the sheathing loom off the harness and check really close.Plus pull the front panel. If you have a module close to the radiator,then you DON'T have the ecm module!! You would have just a regulator rectifier!(changed to ecm modules during mid 2004) To eliminate the battery after it's fully charged you can have it load tested at any auto store for a possible dead cell(plus is it a sealed battery or can you add distilled water?) Could be low and shorted out?? OPT
Old 12-01-2011, 10:26 AM
i can add water to the battery. im going to go out and mess with all the wires again. I'll take the battery in and get it tested and try that. thanks, let ya know what i find. I really don't want to have to load it n take it in i live way up in the mountains and its a major pain. And i know once i get it there it'll be something minor. This seems to happen every winter with this thing. Also, with the red kill switch i can read were it's suppose to be i can move it into 3 different positions do you know which position it's suppose to be in?
Old 12-01-2011, 11:16 AM
In the middle! Far left or far right is the emergency ignition kill position! This is a safety function that cuts all power! Please don't tell me you've had it in the off position!! OPT
Old 12-01-2011, 02:04 PM
no, it's in the middle so that's not the problem i'm trying to clean all the plugs know and battery cables to see if that does anything. still having no luck, thanks again.
Thread Thread Starter Forum Replies Last Post
Buying new vs used? neilbedwell Buying an ATV 23 01-18-2016 12:57 PM
05 polaris sportsman 500 ecm issue??? whitty Polaris ATVs - Ask an Expert! 64 01-05-2016 02:29 AM
Polaris ACE Video Contest ATVC Correspondent General RUV / UTV Discussion 0 06-09-2015 10:14 PM
2008 Sportsman 300 Input? Schneider Polaris ATVs - Ask an Expert! 7 06-04-2015 11:37 AM
Weekly Used ATV Deal: Sportsman 800 EFI ATVC Correspondent Classifieds, Garage Sale & Swap Shop 0 05-27-2015 11:15 AM
Tags
04 , 2004 , 500 , battery , checking , key , kill , polaris , power , pull , sportsman , start , switch , test , turn , wont , wrong
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
