06 Polaris 450
06 Polaris 450
Help!!!! This is driving me nuts.Nut sure just what the problem is ... install a new battery on the atv ... ride for for few hours ... tool light goes on..on the display .. for a short time then the engine dies... this is tells me running off the battery and not charging ???. Recharge the battery ... again does the same thing ... what can this be...
First check that if it is charging back to the battery,14 volts or so. Have the battery load tested if it is charging to see if it can hold the charge. If it's not charging back to the battery and you've had the ecm replaced under the original recall and is on record ,Polaris wont pay for a second one. At least I could never get a second one warrantied.Sucks I know as I've had to replace multiple ecms on the same atvs and several members on the forum have also. Just check around as to who has the best prices. This one box imo controls too many things: charging,fan operation,circuit breakers,battery protection circuits,etc. Too many things to go wrong,but really no way around the ecm.
