500x2 efi Help!!
500x2 efi Help!!
HI guys. I just bought a sportsman 500x2 efi 2007 that doesnt run well. It idles fine, but stalls after around 4000-4500rpm. it shows codes 22 47 58 56 55 41 45. Short circuit? I have replaced the harness to the map sensor. Also the light on the instrument is still on without ignition. And the fuel gauge is gone ?? Sorry for bad english, I am from Sweden..
thanks. Is it possible to check if the fuelpump is broken? I have alreade removed the battery Cables without result. I saw today that the grommet to the map sensor was damaged! Do you Think that can be a problem? And theres a ticking sound from the IACvalve when ignition is on? thanks
