Speedometer not working
Ground was part of the problem since you have awd in forward now. No awd in reverse even with the over ride button pushed could be a roll cage problem or could be a problem in the over ride itself. Read this about bypassing the over ride and you might give it a try..http://www.idofishing.com/forum/show...everse-overide
happened to my sportsman, literally all it needed was a new fuse. should definitely check that first.
Quadovator makes a reverse override lock kit for newer Sportsmans and a reverse override eliminator for later models. You may want to look at these.
Reverse Override Lock Kit Polaris ATV Throttle Function Mods AWD
ATV Accessory ATV parts, ATV tires, Quadovator ATV Accessories
Ckieffer29
12
02-16-2016 05:03 AM
amalota
02-05-2016 01:45 PM
shore
02-04-2016 10:42 AM
