Speedometer not working
No display on speed or nothing at all? If it's not displaying speed it's usually a hall effect sensor located on the right front caliper that shorts out. aIf it's black,probably a connection problem. Should be a red wire that's hot at all times in the speedo connector for memory. Pins can pull back from connectors causing problems also. Best to have the manual on this as it goes into detail on the 16 pin harness connector and trouble shooting.
Okay that's what I was hoping for. Everything works except the speed. I took it to a shop to get the awd fixed and the first thing they did was order a $400 speedometer and it took them 2 months to do it. I finally got tired of waiting so I picked it up and when the part came in I put it on myself.. no changes
Then best to just spend the 5 bucks on the manual as it goes into detail on the 16 pin speedo connector along with a good wiring diagram.Problem may just be in the harness not the entire system.2003 Polaris Sportsman 600 Service Manual PDF Download
With a volt meter or test light check that you have voltage to the front diff hot wire with the key on,in gear and awd button engaged.You can check this at the connector. If you have power,then could be a faulty ground wire or internal diff problems as these centralized systems had problems with roller cages cracking.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse One other step you can take (if diff power wire has voltage) is to regound the differential brown wire to a better ground site and see if awd works then.
