Polaris no Juice
This model might be "iffy"as it's really considered a 2005 model as far as most parts go. If so you should have an ecm module instead of a regulator/rectifier and separate circuit breaker. Check up from the battery under the rear fender to make sure you don't have a circuit breaker in a sealed pouch. If you don't you will probably have the ecm module located under the front panel. Item#23 on the parts break down. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse This module has been updated and possible it may be included in this recall at no charge if you still have the black Chinese ecm module installed. I'd call a local dealer with your vin# and see if you can get it warrantied.http://www.cpsc.gov/en/Recalls/2008/...o-Fire-Hazard/ http://www.ebay.com/itm/2004-2006-PO...FUQWph&vxp=mtr
jeffreybandel
01-18-2016 04:49 PM
trouttracker
01-08-2016 02:07 PM
trouttracker
01-03-2016 04:48 PM
