Battery light
Battery light
My battery light started flashing on my 03 600. It runs good and everything it just started doing this one day. Someone told me it's a bad regulator so I ordered a new one but Ithe hasn't came in yet. Is there anything else it could be if that's not the problem? Its never died but I always take it back to camp as soon as it starts. I've noticed ifor it sits and idles for a second it goes away, probably coming on when the fan does.
You again... What was the charging rate back to the battery at an idle? Should be around 14 volts or so. Like we talked about if you still have the Ducati ignition,trash it and get the Kokusan IF you plan on keeping the 600 engine. Charging problems was just one of the problems the Ducati system had along with hard starting back, firing and leaving people stranded. Possibly could be a regulator,but if it's the stator,they're NLA,plus the stator will fail sooner or later. Plus don't even bother with the cheaper RM ignition kit as it uses the Ducati lighting coil for an ignition source and it can fail also and your stuck again if it goes out. Just get the #2202603 Kokusan kit and be done with it. Comes with a new stator,flywheel,cdi,coil regulator,jumper wires plus it changes this system to the later,more reliable dci ignition system.
Don't even bother on testing anything!! I went through this same thing before the updated kits came out. I replaced coil packs,regulators to only have them come back in when complete stators died. After going back and forth on about 5 or 6 like this I went to order a new Ducati stator for one and found that Polaris has suddenly substituted the stator with the new complete kits. Dealers weren't informed on the change by any sort of bulletin and nether were customers as it was an over night thing by Polaris. ALL of these ignitions should have been on a recall but weren't. I've changed out enough of these parts to know it's like chasing your tail,you ain't gonna catch it. Don't be fooled by any used Ducati parts on ebay either as some have found out the hard way also. Bite your tongue,save your nickels and dimes if you have to and get the right kit.
