Trail boss transmission identification/ parts help
Hi All,
My son brought home what he said was a 96 trail boss with a bad transmission. I took a look and determined it was inside. The forward dog gears were rounded.
I started looking for parts and decided let me determine what year it is.
The hood vin is 2505098. With a mfg date of 011194.
The transmission is model 1341151 sn 95-67334.
Can someone please help me this? Looks like a 94 with a 95 transmission?
Forward gears are not available for 94/95, will the 96 parts work?
Any help would be greatly appreciated!
Thanks
Thanks
Sounds like you have a mess. Look on the right frame down tube. If it's a 96 it will show "W968527"
Gear cases that can interchange or used the same one are listed here.
Usage : 1341151
Year Product Model Assembly
1999 ATV TRAIL BOSS GEARCASE - A99AA25CA (4949594959c003)
1998 ATV TRAIL BOSS GEARCASE Trail Boss W98AA25C (4945314531C003)
1997 ATV TRAIL BOSS GEARCASE Trail Boss W97AA25C (4940574057C003)
1996 ATV TRAIL BOSS GEARCASE Trail Boss W968527 (4935883588C004)
1995 ATV TRAIL BLAZER GEARCASE ASSEMBLY Trail Blazer W957221 (4930363036C005)
1995 ATV TRAIL BOSS 250 GEARCASE ASSEMBLY Trail Boss W958527 (4930323032C004)
Usage : 1341151
Thank you for this information. So the vin 2505098 was so amped into the down tube, similar to my suzukis. I looked again and under the front fender on the frame I found the W958527. 7074897.
Will the 96 forward dog fit this transmission? If I cannot find the parts
Thanks again for the help
Well I appreciate your time Old Polaris Tech!. I think based on the lower serial number of my unit vs the two series they offer for the 1995 (that you showed). I think it's safe to say this is a late 1994 production transmission. The 94 forward dog 3233107 is the same as the lower serial number offering for the 1995.
Plus my local,Polaris shop couldn't offer any assistance.
Thanks again
Thanks again
Normally that tells you the forward engagement gears that the 2 tab and 3 tab dog gear (engagement gear,3233107/3233184) lock into would be different and they are. Your best bet since a lot of these gears are nla is to try to find a used gear case of your same model and use the best parts on one.
