2000 335 Speedometer trouble - ATVConnection.com ATV Enthusiast Community
Thread Tools Search this Thread
Old 02-21-2017, 10:01 PM
mrstangblb's Avatar
Default 2000 335 Speedometer trouble
The guy I bought my 2000 335 from said the speedometer was working yesterday when he was riding it. Now it's not.
I took the headlight pod loose and cleaned the speedometer contacts with electrical cleaner, and I connected and disconnected both wire clusters that plug into the back of the speedometer. Still not registering or showing digital readout. There is no light illuminating the speedometer, either.
Again - thanks for any help. I've gotten great responses to my other posts and I truly appreciate it. I'm a little disappointed in this purchase, but I'm going to work it out - especially with your help!
Barry
Jeremiah 29:11-13 / John 3:16
Old 02-21-2017, 10:02 PM
mrstangblb's Avatar
Plus I've read posts about batteries going out and ruining a speedometer - but he said when he was riding yesterday that it was working.
Old 02-22-2017, 10:48 AM
Speedos can go out at any time and are expensive to replace. Some are showing nla also. If you like tearing things apart here's a couple posts on this. One from a forum member.KA7OEI's blog: Repair of the speedometer on a Polaris Sportsman 500 4-wheeler
AWD and Speedometer don't work - Page 2 - ATVConnection.com ATV Enthusiast Community Also this was one of the last mechanical speedos that used and cable,gear case adapter and key. Keys were a common item to break as they were simply a short piece of cable that connected the gear case to the adapter and speedo cable. This may be your problem. Item #46.
Old 02-22-2017, 12:11 PM
mrstangblb's Avatar
Thumbs up
I was watching several YouTube videos last night showing how to open the hood shroud and short 4 wires together to a common ground. The post you have showing to ground just the 2 in the speedo plug may be what I do this weekend. That's a LOT easier than anything else for now!
And the transistor fix may be something I try, too - it would be well worth it. I've never unsoldered anything - only soldered - but there's nothing to lose. Thanks VERY much!
Old 02-22-2017, 12:34 PM
Ahhh.. I was looking at the AA model that had the mechanical speedo. Other 2000 model 335s had the newer electronic speedo. The older one you could find for about 150 bucks.Newer style is double that. As far as grounding the wires this was mainly to regain awd ground that went through the speedo. Jumping the brown/white to brown or to a good frame ground bypassed the speedo ground and sometimes helped restore awd also. Ground shouldn't have gone through it to begin with for the awd.The one you probably looked at was from the awd connector browns to a common ground. Long thin wires that could loose ground and this was a good fix. Hope you can get the speedo fixed and save some $$ also.
Old 02-22-2017, 01:40 PM
mrstangblb's Avatar
Thumbs up
If Radio Shack still has some of these transistors I'm going to sure try it. I'll still probably short the 2 wires to make SURE the AWD works. Thanks for your prompt answers - I get impatient easily and this had me going, but your answers are helping my anxiety level.
Old 02-23-2017, 07:37 AM
mrstangblb's Avatar
​​​​​​​You don't happen to have a headlight pod for this model, do you?
Old 02-23-2017, 09:34 AM
Old 02-23-2017, 12:52 PM
mrstangblb's Avatar
I see one on BikeBandit.com for $66 or so but I'd just as soon get a used one cheap somewhere. I don't need everything - just the plastic shroud.
Old 02-23-2017, 12:59 PM
Brain dead again.. thinking speedo.. Yes check Partzilla (I think 54 bucks) Cheap Cycle parts and Cycle Parts Warehouse also.Main thing is make sure you order the right color. That's the main difference on series numbers such as AA,AB,etc.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
