OPT help with AWD - ATVConnection.com ATV Enthusiast Community
Thread Tools Search this Thread
Old 03-20-2017, 07:13 PM
Default OPT help with AWD
OPT a buddy just bought a 2007 Scrambler 500. Bought it knowing the ecu was bad. The old owner had bypassed it with some funky wiring. He has ordered a new one, the guy said that the the awd doesn't fully engage because of it. My buddy said it seems to pull hard left. Does the ecu control engagement of both front wheels? I would have thought it just engaged the main shaft and it was full power to both wheels then. Thanks in advance.
Old 03-21-2017, 05:07 AM
This sounds more mechanical related like an armature plate in the hub that's magnetized.This will cause one side to engage even with awd off.Changing fluid may help,but kinda doubt it. Replace both plates when you do as the other one would probably need replacing later any way.Ecm doesn't control the awd,but get it replaced. Here's a video on the hubs and hilliard. Lay off the grease as simple hub fluid coating will work better.
Old 03-21-2017, 05:54 AM
Thanks! I will pass this on.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
