2013 ranger 800 Efi loosing power at 180 deg - ATVConnection.com ATV Enthusiast Community
Thread Tools Search this Thread
Old 01-08-2016, 07:44 PM
Default 2013 ranger 800 Efi loosing power at 180 deg
My 2013 ranger 800 Efi after the temp hits 180 deg. Will bog an stall when I try an excellrate. I've checked fuel pressure it holds at 50lb the strainer is clean as well, I checked tps an the other two sensors on that wiring harness for cracks an chafes . It has no service codes on screen. When it's cold it seems to run fine but as soon as it hits 180 deg is when the trouble starts... HELP !!
Old 01-09-2016, 07:54 AM
Fuel pressure is a little on the high side. Should be around 39 psi or so. Don't know if that is a problem,but you might try removing the radiator cap,raising the machine on it's side and try to bleed off any trapped air pockets that could be causing the problem. Plus because of the long radiator hose runs on the Rangers,there should be a bleed screw at the thermostat housing also to purge any trapped air.With no codes showing kinda hard to track down something like this. Still could be a t-bap wiring harness problem or the ecu could just be going into limp mode. If all else fails having it hooked up to Digital Wrench may be the best solution.
Thread Thread Starter Forum Replies Last Post
2013 polaris ranger 400 patokalake64 Introduce Yourself 4 01-08-2016 08:13 AM
BuYang wiring help? Lowandroll Chinese Quads 1 01-06-2016 08:28 PM
Stalled my 2008 Sportsman EFI in the water and now it won't start.. Tradermgp Polaris 2 12-26-2015 10:12 AM
high oil pressure Mac25 Polaris 2 12-23-2015 12:47 PM
87 cyclone 250x not starting/no fuel????? stow_senior Polaris ATVs - Ask an Expert! 13 12-18-2015 01:20 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
